i have baught a kit from halfords to correctly wire in my spots, however, i am having trouble locating the main beam wire. in the haynes manual it says it is bl/w, but when i use this wire, it does not work?!?! if i use the diped wire they come on, but i want them to work when i flash, any help would be great1 (its a 1992 cooper injection)
spoght light wireing kit
psycho mini driver
, Jan 26 2005 09:38 PM
4 replies to this topic
Posted 26 January 2005 - 09:38 PM
Posted 26 January 2005 - 10:02 PM
Well you're right that it is the blue/white wire you are looking for, can't say why it isn't working. Any more info? Does anything else not work, how did you connect it?
You can't wire them into the dipped circuit anyway, additional main beam lamps MUST extinguish automatically when you knock the standard main beam off and it must not be possible to leave them on accidentally on their own.
Posted 26 January 2005 - 10:21 PM
Unless you're in Cyprus
Posted 27 January 2005 - 07:55 AM
I believe the bl/w wire is correct... but make sure you had a clean ground. I've had all my lights stop working because their ground was C**p.
Posted 27 January 2005 - 10:50 PM
il check the eath, i used an existing hole, so it could have had some surface rust and a poor conection thinking about it.
