Clocks
Boab
, Jan 31 2005 07:14 PM
6 replies to this topic
Posted 31 January 2005 - 07:14 PM
Will a 3 clock cluster fit straight into my mini or does it need extra wiring?
What is the spade terminal and prong for on the rear of the tacho?
Posted 31 January 2005 - 07:18 PM
What setup do u currently have?
All depends on how much wiring you want to do. but i heard it was alot of hard work to fit a 2 or 3 clock setup to my centre clock 1980 mini.
Posted 31 January 2005 - 08:37 PM
I have the wiring for a 2 clock setup, but would like to put a tacho in as well.
Posted 31 January 2005 - 09:07 PM
Should drop right in! There should be the two connectors you need behind the dash coming off the loom somewhere. One spade and one bullet I believe? One of them is definitely white with a black tracer and the other I don't remember the colour but they should be together...
Posted 31 January 2005 - 09:22 PM
Bingo. I remember them being there when doing a quick fix and wondered what they were for. But I'm sure there were 3 wires. I will try them next week when the interior rebuild begins in earnest. I can't wait.Should drop right in! There should be the two connectors you need behind the dash coming off the loom somewhere. One spade and one bullet I believe? One of them is definitely white with a black tracer and the other I don't remember the colour but they should be together...
Posted 31 January 2005 - 09:50 PM
do you have the bracket as well as they are wider to take the 3 clocks ?
Posted 31 January 2005 - 09:59 PM
I bought a job lot off ebay with various brackets and 4 sets of clocks, but not splitting(3x Smiths). I will be putting the best set, probably the 120mph one, into my car then the rest will be incorporated into dash boards I am planning to make and sold on ebay to the highest bidders.
