1380 Pricing
Posted 12 September 2007 - 10:19 AM
at the moment iv got a 1275 spi cooper and was wondering how much it would cost to upgrade it to a 1380 including labour parts etc?
Thanks Ben
Posted 12 September 2007 - 10:21 AM
Posted 12 September 2007 - 11:21 AM
Posted 12 September 2007 - 11:22 AM
My local machine shop will bore the block for £100 offset or not.
I am going to use the hepolite pistons as i am on a very tight buget(5 kids)
They are not the best but thet will do for me and you are looking at £180ish for them.
hope this helps
Obviously you will need gaskets,in my case a better carb and exhaust,and i dare say loads of bits and bobs you can not add up till you do it.
Posted 12 September 2007 - 12:18 PM
Unless you're ditching the Injection system.
Edited by Retro_10s, 12 September 2007 - 12:19 PM.
Posted 12 September 2007 - 12:42 PM
Depends what power he hopes to make. I believe its the map that runs out of fuel above 90bhp?Erm, this is an SPi right?... I didn't think the SPi ecu could handle a 1380 without some jiggery pokey i.e.... replace it.
Moved to 'Injection Specific'.
Posted 12 September 2007 - 01:48 PM
Varies widly between spec and company/engine builder. So I'm going with £600-£10,000.
*£600 - £14,450* MED have just released 8 port prices
Posted 12 September 2007 - 05:08 PM
above 90 bhp and you struggle to get it through an emissions test. You can get it through an emissions test but it then runs mega lean at wide open throttle.
100bhp + is achieveble if you take this into consideration and that is on a standard ECU. The trick is knowing how to do this.
