Wanted: Spi Tuning Guide
8 replies to this topic
#1 John H
John H
  • 768 posts
Posted 12 September 2007 - 07:21 PM
Righto starting from scratch without pulling the spi stuff off what do people reccomend to make a driveable quick motor.
John
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 12 September 2007 - 09:11 PM
Maniflow LCB
Big exhaust
37 x 29mm valve gas flowed head
1.5:1 ratio roller tip rockers
11:1 compression ratio
Kent 274 scatter pattern cam
Lightened Vernier timing gear
Lightened cam followers
Fully lightened crank
Lightened con rods
Ultra light flywheel and backplate with orange diaphragm and AP racing friction plate (requires crank sensor kit from either KAD or Specialist Components)
Full engine balance
inlet manifold ported to match head and doweled to locate
Throttle body modified to 44mm
Throttle body ported to match inlet manifold
Larger injector from Rover K8 1.4SPi engine
Cooper SPi ECU
3.44:1 final drive
Recon on about 80 - 100bhp dependant on CC but expect issues at the higher end on the standard ECU with fueling and emissions no matter what you do
keep the CC to the standard over sizes and i doubt you will have a problem, the car will be extremely lively. Dont get hung up on the numbers of bhp, its the feel of the drive, not the power output that matters.
#3 John H
John H
  • 768 posts
Posted 13 September 2007 - 09:40 AM
will the 11:1 not cause pinking? or will the ecu sort it out?
not too bothered about big numbers i just want a nice drive.
Edited by minimadmotorman, 13 September 2007 - 09:45 AM.
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 13 September 2007 - 04:55 PM
yes you will need to run at least 97 RON unleaded
i ran 11.5:1 on a standard ECU with 99 RON
#5 John H
John H
  • 768 posts
Posted 13 September 2007 - 08:25 PM
cheers sprocket. i will get started.
Edited by minimadmotorman, 13 September 2007 - 09:22 PM.
#6 Major Burkenshaw
Major Burkenshaw
  • 638 posts
  • Local Club: Brighton mini club
Posted 01 October 2007 - 05:38 PM
Would using Rimflow valves on the inlet give any real gain?
Also what route would you go down to alter CR? (different stoke length, different pistons etc?)
#7 Sprocket
Sprocket
  • 7,266 posts
Posted 01 October 2007 - 06:43 PM
Rimflowif you have the money and the rest of the head is optimised, not much use on a standard head.
Skim the head to get the compression up, you could also skim the block in some instancies, IE the non cooper engine has roughly 4cc above the piston, excluding the piston dish.
#8 Major Burkenshaw
Major Burkenshaw
  • 638 posts
Posted 01 October 2007 - 07:19 PM
Is it only worth using the rimflow valves on the inlet side?
I think i'm going to have to rob the piggy bank soon :lol:
#9 Sprocket
Sprocket
  • 7,266 posts
Posted 01 October 2007 - 09:54 PM
Did you get your wiring issue sorted in the end dude?
