Exhaust Back Box Change
Posted 17 September 2007 - 03:44 PM
if i was just replacing the backbox does it needed to be welded to the link pipe or does it bolt on etc?? unfortunalty my mini is at the garage so i cant physically look!
planning on fitting a side exit 2" playmini back box and need to know if it requires welding??
cheers
Posted 17 September 2007 - 04:13 PM
There are two side exit playmini exhausts, the big bore and the small bore. The big bore has a 2 1/2" tail pipe, but the system is 2". The small bore is a 2" tail pipe but a 1 3/4" system.
Either require the apropriate cat link pipe enabling the backbox to bolt straight to the cat in a like for like way, the only thing extra you will need is an exhaust clamp.
I dont know of any aftermarket system that is designed to fit the mini requiring welding so you should be alright there
Edited by Mini Sprocket, 17 September 2007 - 04:15 PM.
Posted 17 September 2007 - 04:21 PM
Which bit of the play mini are you describing as 2"??
yeah thats what i thought just wanted to double check before i buy an exhaust and find i have to weld it!
cheers bud!
Posted 18 September 2007 - 12:22 PM
Posted 18 September 2007 - 12:25 PM
