Had a devil of a time removing my clutch and ended up grinding it off so am just left with the flywheel. When I reassemble it all is there anything I need to look out for? Specifically the position of the assembly on the crankshaft. Will the Sensor pick up and sort out the timing or do i need to put it on a certain way?
The Haynes manual doesn't specify anything.
Cheers - John
Spi Flywheel
NudgerSS
, Sep 29 2007 03:57 PM
No replies to this topic
