Harry if this was the case you would get bore wash on the other cylinders due to over fueling.
I think Giles' problem is more than likely down to the fact he has modified his car quiet abit, therefore effecting the fueling.
Tell that to everyone who has failed an emissions test with an LCB on, the immediately passed once the std exhaust is back on.
Emissions wasnt miles out, i think its the 52mm throttle body which is causing the problem, we shall see next week.
Plan is to take the high lift rockers out and replace with the standard ones, and put the standard throttle body back in. Hopefully this will bring down emissions down enough.
Edited by CooperTrooper, 04 October 2007 - 12:25 PM.
