Right I have very little understanding in this matter so need you to help me.
I need to remove the engine from the car but don't want to have to rebleed the entire braking system! Is it possible to remove the actual big servo unit while retaining the brake master cylinder or do they all go as one?
Removing servo
Pavel
, Feb 14 2005 07:21 PM
4 replies to this topic
Posted 14 February 2005 - 07:21 PM
Posted 14 February 2005 - 08:33 PM
if it is what i am thinking, then there are two copper hoses that are attatched to the servo, remove theese two, then there are three bolts on the back of the servo. just undo these and whip it out, did this when pulling the engine out. the brakes did need a little bleeding but not a great deal
Posted 14 February 2005 - 10:04 PM
My engine has been out and in again twice without removing the servo .
Posted 15 February 2005 - 06:21 PM
i suppose if you undo the retaining bolts for the servo and bend it out of theway you could get the engine out!!
Posted 17 February 2005 - 07:27 PM
If you're carefull swinging the engine they come out ok with the servoand master in.
Find it helpful to have an extra pair of hands to guide the engine.
