4 Pot Caliper Choice
12 replies to this topic
#1 brandon7
brandon7
  • 274 posts
Posted 28 October 2007 - 10:22 PM
Just prepping all of the other components for my z car while im saving my last few bucks for my bike engined kit.
I have some standard hub assembelys ive cleaned up. Im looking to replace the disks with vented disks and the standard calipers with 4 pots
Are metro 4 pots up to the job? Or can anyone recommend anything else ideal for Z car with mostly trackday use and hillclimbing? Im looking to get them second hand and save as much cash as possible without getting stupid about it as this is obviously an important thing.
If anyone could spec out a good kit of disks, calipers and pads that would be great! Cheers
#2 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 02 November 2007 - 01:24 PM
Metro or KAD 4 pots on 8.4" discs are a minimum std in my opinion. I would recommend wilwood really as they are a good compromise between value and performance compared to the likes of AP Racing gear.
At the end of the day you could spend a lot of time grafting something on from a scrapyard find but will it work well and be safe???? You shouldnt compromise on brakes and suspension.
cheers
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,568 posts
  • Local Club: Amoc
Posted 02 November 2007 - 03:15 PM
you would need Metro Turbo brakes for the conversion I would say and Decent Drilled and grooved discs.
Personally I thing mark is right Brakes are most importat ( well after the engine) ( GO GO PART v's STOP STOP PART)
#4 philmin
philmin
  • 136 posts
  • Local Club: QQQQQ
Posted 02 November 2007 - 10:53 PM
I just did a Metro four-pot caliper conversion as seemed straightforward, will let you know if they are good enough or not when I get a drive! :withstupid:
word of warning if you go down this route, only people I have found doing hose conversions kits for the Mini to these brakes are Goodridge, and they are awful quality kits, I am now on my second set and the car hasn't turned a wheel yet. The bolts once fitted to the caliper seem to stretch, meaning that if you take them off for any reason you will never get another good seal, even with new copper washers.
#5 brandon7
brandon7
  • 274 posts
Posted 03 November 2007 - 06:07 PM
Thanks for the advise. So for the amount of hassle in the conversion a set of willwoods would be better. I hear though cast steel breaks like MG trbo get rid of heat very well also where as aluminum calipers and disks store heat.?
Does anone have any expierence with the Minisport made 4 pot calipers? Cheers
Also which mini grooved disks would someone recommend. Not toooooo expensive!
#6 z cars chris
z cars chris
  • 469 posts
Posted 03 November 2007 - 09:12 PM
i know we sell the kits so i suppose im biased BUT i tried every type of caliper on the front of our cars and they all struggled to stop as good as i wanted them too
the six pot tarox were very good but too good you couldnt feel for grip and locked up too easily
we then invented our own brake set up and on track i can out brake pretty much everything im up against and make no mistake ive mixed it this year with some very nice cars
the trick of good brakes lies in the front to rear balance, the correct size so they work well and dont overheat,or are too good and you loe feel
if you ask anyone who has had one of our demos most will tell you that the power surprised them most will tell you they were surprised by the traction but all seem to be surprised with the brakes
i think that they are as good as we can get them and wont be changing anything for the race series even if we introduce a class for hyabusa turbos for example in the future
chris
#7 brandon7
brandon7
  • 274 posts
Posted 04 November 2007 - 02:47 PM
I would not doubt any of this sounds great. But with adding together all of the other costs that have come up from starting my project i was just looking for other ways i could have good brakes without spending nearly £500 if i can avoid it. Whilst wanting good braking.
Got any second hand sets Chris? :thumbsup: Or anyone for that matter
#8 philmin
philmin
  • 136 posts
  • Local Club: QQQQQ
Posted 04 November 2007 - 07:05 PM
ebay - paid £60.00 for my set, need to be patient though. I also hear there is a place in Wrexham (not sure what they are called) that reconditions calipers so condition can be dealt with, do some sleuthing I would.
#9 brightsparkz
brightsparkz
  • 70 posts
Posted 26 November 2007 - 04:32 PM
where can i get wilwood calipers that fit the mini from?
Anyone have any ideas?
S
#10 brandon7
brandon7
  • 274 posts
Posted 06 December 2007 - 11:13 PM
S
z cars online shop
#11 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 06 December 2007 - 11:26 PM
http://www.superfast...rbrake_kit1.htm
works out about £480
#12 Jammy
Jammy
  • 25,397 posts
Posted 07 December 2007 - 09:04 AM
Plus shipping and import duties, might as well just get them from Z Cars.
#13 lukey1019
lukey1019
  • 336 posts
Posted 28 December 2007 - 04:42 PM
These are £480 mind
http://www.minispeed...=kadconversion1
