additional performance
Posted 25 February 2005 - 04:06 PM
Am fairly new to mini ownership, but willing to have a bit of a tinker. So the question is what can I do that's not too expensive to improve on power. Also with regards to the brakes, is there anything to impove those? (other than upgrade to 7.5" setup) I notice that there are EBC greenstuff pads available for mine, will they be better than standard pads for road use?
Any ideas greatfully recieved.
Posted 25 February 2005 - 04:15 PM
greenstuff pads are seen as for race/fast road, but the blackstuff/kevlar pads they do have a wider operating temp making them better for road.
Posted 25 February 2005 - 04:33 PM
Blackstuff pads also have the advantage of being half the price of greenstuff! They sound more up my street useage wise.depends on the type of driving you do.
Off to Minispeed for the VAT free day tomorrow then...
Posted 25 February 2005 - 04:52 PM
I would strongly suggest upgrading the brakes if your going to add any more performance. if you want to keep 10" wheels ( which I would suggest ) you only option is 7.5" disks, or at worst a good well maintained set of drums will out perform you 7" disks.
Also, if the 1275 unit has an engine number, that can be used to find the source of the engine, but in 91 there were a lot of rusty metros around then with hardly used 1275's
Oh, ps... welcome to the joys of mini ownership, sounds like you have a real stunner to start with
Posted 25 February 2005 - 05:04 PM
Indeed stopping is a bit of an issue versus the current acceleration.I surprised you can stop the thing with a 1275 unit and 7" disks, they are next to useless..
If I were to upgrade to 7.5" would exactly would I need? is it just the disks or do I need new everything?
Also where is the engine number located?
Thanks for the welcome :grin:
Posted 25 February 2005 - 05:55 PM
As for upgrading breaks, I *think* you'll only need callipers and the discs.... not sure though as I've never come across changing from 7" to 7.5" queries.
In fact I'm almost positive that you can use your hubs and driveshafts, the only thing you might need to also change is the drive flanges, but I'm not sure of this...
Posted 25 February 2005 - 06:40 PM
Cost wise, I'd buy the Disks, driver flanges and CV's ( if necessary ) new, the're still relatively cheap, the calipers are going to cost the money..
You see them at over-inflated prices at shows, and they sometimes appear on ebay, or you can still buy new Minispares, the alternative id four pot alloys, not cheap but worth every penny.
Posted 25 February 2005 - 07:21 PM
Oh yeah, and the transverse 1275 was also fitted to about a dozen other BL cars over the years. It's unlikely to be a 1275GT version just on the odds alone (very small production figures for the GT when compared to things like the Allegro, the 1300 or the Metro. Is it an A+ or an A series unit?).
Edited by Dan, 25 February 2005 - 08:29 PM.
Posted 25 February 2005 - 07:45 PM
Sell off the calipers for a tenner, and then buy the alloy 4 pots for 10" wheels. They use all the stuff from the 8.4 setup, all you need to do is have the discs turned down to 7.9" (which will simply remove the rusty stuff around the 8.4" discs!), and you've got the best 10" stopping power money can buy.
The alloy 4 pots also come in several very pretty anodized colours... Minisport is the place to get them
Posted 26 February 2005 - 07:25 AM
Posted 26 February 2005 - 04:41 PM
I'm fairly sure that the engine is a A, not an A plus.You do need new CV's as the 7" disc setup is based largely on the original drum, setup and so has the small CV joint. You also need the large CV joint nut and split tapered washer to go with it. You may need to change the hub upright as well, I'm not sure.
I was told that the engine & gearbox did come out of another mini, but that's all I know. Will check tomorrow for engine number, and I'll take a couple of pics.
Is it a particularly difficult job to change the CV's and calipers?, I will be armed with a Haynes manual and a smattering of experience...
Posted 26 February 2005 - 04:45 PM
I think the cooper S had 7.5" but the cooper had 7".just going back to basics for a mo, are you sure its got the 7" discs as they were 7.5 as standard in 68, its seems very unlikely that someone would fit 7s as they were pretty poor performers, just double check first, they may be poor because they need servicing, in good condition they are very good stoppers
Judging by the current stopping performance, I'd guess that I have the 7" , although have never taken a tape measure to them....
Posted 26 February 2005 - 06:36 PM
Posted 26 February 2005 - 06:49 PM
Posted 27 February 2005 - 11:35 AM
