ive got a 1992 spi cooper, and it will not rev. if you are stationary with your foot flat it fluctuates between 2750-3000 and not above. then if you drive it it will drive fine for a short period, then the car will start almost kangarooing.
i dont have a clue where to start with this engine i mean, can u get a code reading from it or a diagnostic machine on it? please any help will be very much appreciated. westy
Spi Cooper
westy1990
, Oct 29 2007 09:29 PM
6 replies to this topic
Posted 29 October 2007 - 09:29 PM
Posted 29 October 2007 - 09:45 PM
Moved to Injection Problems.
Posted 29 October 2007 - 09:49 PM
Posted 29 October 2007 - 09:53 PM
Oh and if you have been driving it like this for any lenth of time, the cat will have melted, compounding the problem.
Posted 29 October 2007 - 10:39 PM
Does it idle correctly?
Posted 30 October 2007 - 06:44 PM
nah it aint been driving as soon as it started doin it, but im de-catting it anyway.
it starts on the button and idles sweet as. just when u touch that throttle.
cheers for ur help so far ill have to try a tps cheers
Posted 30 October 2007 - 07:24 PM
No!!
I posted the link to the part you need
Its thot the TPS (Throttle Position Sensor), its the throttle switch, its totaly different and only on the SPi Mini up to 93, it fits behind the throttle pedal, a spring pulls the throttle pedal back to ensure the switch is closed, there is a circular disc on the throttle pedal arm that acts on the switch, it is this switch that is the problem. This switch provides the ecu with inforamtion telling it that the engine is in an idle condition, if its stuck, when you press the accelerator, the ecu still thinks its in an idle condition yet the engine speed is rising, the ecu then retards the ignition and backs off the stepper, this causes the symptoms you are experiencing.
I am sure this is the problem but without actualy looking at the car my self, there is still a slim possability it is something else. Minisport couldnt diagnose this problem
Double check the thin black and red capilary lines that connect to the manifold and ECU, make sure they are all in really GOOD condition and connected as they should be. This also gives similar symptoms.
