hello... this is not for me but my freind who does not have the intnet. He has a 998 city he brought a 1275 metro for 50 QWID! lol and there going to put the metro engine into the mini. but the mini is hydralic clutch but i think dean said the metro was cable or maybe the other way round not sure, any how he does not know what to do about this.... any pointers or diagrams i can print of n give to him???
998 to 1275 metro..
miniman5
, Feb 27 2005 10:03 AM
5 replies to this topic
Posted 27 February 2005 - 10:03 AM
Posted 27 February 2005 - 10:42 AM
Most metros had hydraulic clutches but some had a cable operated clutch. I'm not sure which internal parts are interchangeable but I'd simply take the clutch and flywheel from the 998, along with the flywheel cover, the clutch arm, and the slave cylinder from the current car.
Posted 27 February 2005 - 11:56 AM
and put it onto the metro engine??
Posted 27 February 2005 - 02:15 PM
yup
Posted 27 February 2005 - 06:56 PM
Ooooh, I wouldn't do that. You don't want to disturb the setup of a Verto clutch unless you are going to also replace the clutch disc, as the self adjusting action makes it hard to get the adjustment right without all the parts being new. All you need to change on the Metro clutch is the release arm. Cut out the split pin and pull the clevis pin, remove the release arm and replace with a hydraulic type Verto arm. If the 998 is Verto then you can use the whole verto release assembly from that including he release arm, if not then you need to find a release arm, slave cylinder, bracket and all the sundries to put it together.
Posted 27 February 2005 - 07:46 PM
I actually meant to change the clutch disc too dan (good opportunity to fit a new one), but your way does sound much easier indeed.
Of course if he wants to go to a non-verto clutch, the first method will have to be used (replace the entire clutch assembly)
