R1 FWD Mini
19 replies to this topic
#1 R1mini
R1mini
  • 1,385 posts
Posted 27 February 2005 - 10:57 PM
Hello all,
My name is David and I'm building a R1 front wheel drive mini, anyone else doing anything similar? It has been a differcult and expensive to sort the drive out but it's geting there
David
#2 Jackman
Jackman
  • 4,053 posts
Posted 27 February 2005 - 10:59 PM
If you check the project section there are a few people doing a similar conversion.
Welcome to the forum also.
#3 Jordie
Jordie
  • 13,564 posts
  • Name: Jordan
Posted 27 February 2005 - 11:04 PM
all rwd drive in projects i think.
Wont FWD effect the turning when under power, torque steer is it called......i cant remember
Good luck with it and welcome!
#4 R1mini
R1mini
  • 1,385 posts
Posted 27 February 2005 - 11:16 PM
Thanks for the welcome,
Jordie, I will use equal length driveshafts to eliminate torque steer, I will try and add a picture in the reply body didn't work on the first post I will try again
Edited by R1mini, 30 May 2010 - 03:46 PM.
#5 Jordie
Jordie
  • 13,564 posts
  • Name: Jordan
Posted 27 February 2005 - 11:19 PM
Sounds good, look forward to see it finished
#6 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 February 2005 - 11:46 PM
cool i'm building a rwd car
#7 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 February 2005 - 11:48 PM
Have you consulted with Rallysportreplicas
they will do you a full conversion kit if you want, but best of all is theri gearbox with reverse on!
#8 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 February 2005 - 11:50 PM
torque steer won't be an issue as the R1 engine will produce big power top end and flat out. The added weight of the mini stuff is perfect for solid low end power but awesome mid range to top.
#9 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 February 2005 - 11:51 PM
Don't get me wrong tho, the bottom end power is more than adequate
#10 R1mini
R1mini
  • 1,385 posts
Posted 28 February 2005 - 04:48 PM
I had a talk with the people at rallysportreplicas, I think they are a while off yet and they will use a short bike chain, which I know does not work unless it's in an oil bath. We shall see, I might still interested with their kit if they can sort it out soon
I will call them see if they are any closer to having the kits available so I can actually see what it consists off, that would making a decision easier, the stuff I have bought won't go waste
David
#11 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 February 2005 - 05:01 PM
They reckon their gearbox will take shaft drive
#12 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 28 February 2005 - 05:05 PM
http://www.theminifo...pic=1408&st=330
#13 R1mini
R1mini
  • 1,385 posts
Posted 28 February 2005 - 05:14 PM
That's the rear wheel drive gearbox, I'm doing fwd which they say they have a modded mini gearbox on the way, driven by a short chain suitable for a R1.
I tried to call him today to see how they are getting on, no luck today I will try again tommorrow
David
#14 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 28 February 2005 - 06:34 PM
hello and welcome to the mini forum
#15 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 01 March 2005 - 07:59 AM
I spoke to him yesterday and the gearbox willl be released soon for £1295 not bad eh.
But to build his kit myself in my minus he recons £5500! and that's not even with the equal length drive shafts. Don't know where that money is going.
