Spi Manifold Vacuum Hoses
6 replies to this topic
#1 BRGRover92
BRGRover92
  • 18 posts
Posted 06 November 2007 - 08:42 AM
Hello, i searched the forum and could find an answer to this one.....There are 2 vacuum hoses that come out the back of a SPI inlet manifold. One of mine goes to the fuel trap then on to the MAP sensor and the other doesn't go anywhere. What should this be connected to? My guess is the air cleaner?? Help!!
#2 Jordan
Jordan
  • 44 posts
Posted 06 November 2007 - 08:50 AM
i think the other one is red if it is it should connect to the air box unless you have a K&N cone filter in which case thier should be a screw in the end of the pipe.
jordan
#3 Jammy
Jammy
  • 25,397 posts
Posted 06 November 2007 - 09:01 AM
Moved to Injection.
#4 BRGRover92
BRGRover92
  • 18 posts
Posted 06 November 2007 - 09:06 AM
jordan
No K&N on my mini, just the standard air cleaner box and no it isnt piped up with any hoses.....
#5 Jordan
Jordan
  • 44 posts
Posted 06 November 2007 - 11:23 AM
ok this is of the top of my head so please bear with me if i am wrong. On hte under side of the air box you should have two connection points and a brass nut moulded into the plastic the brass nut should have a green sensor screwed into it, the connection point in between the green sesnor and the outer connection point is where the red pipe goes, the outer connection point you should have a yellow pipe which connects to a thing on top of the air box.
Hope this makes sense, i don't know the actual names so i hope somebody else will be able to correct any thing i have said that is wrong.
can i just ask do you have a white pipe going to the fuel trap
jordan
#6 Jordan
Jordan
  • 44 posts
Posted 06 November 2007 - 11:26 AM
the link shows the fitting of a K&N air filter but will help you under stand what i was writing
Link
#7 BRGRover92
BRGRover92
  • 18 posts
Posted 07 November 2007 - 05:50 AM
Thats sounds good to me. My air cleaner box doesnt have any hoses or pipework at all connected to it, no colours or right angled fittings... I will have to pipe it up from scratch... Thanks Mate!
