Indicator Problem
Best Answer Jordan18 , 07 December 2015 - 09:53 PM
I found the problem, thanks any turns out I didn't have any break lights as well, it was a blown fuse but it had broken in a way when I went over bumps or dips they would connect and complete the circuit then break again.
Thanks,
Go to the full post
Posted 06 November 2007 - 02:25 PM
I finally got the car of my dreams a mini.
Picked up my little 1992 998 city Beauty for £500 with only 36k on the clock with only 2 owners from new.
with 9 months mot and tax perfect sills and new subframes what a bargin.
Here is the catch my indicators worked then my mate put the hazzards on for a laugh and the indicators stopped. check the fuses their fine but when i jiggled the fuse they worked again. but have know stopped. ive fitted a new fuse box which worked but then hazzards went on no indicators no blown fuse.
ive tryed checking the flasher units but cant find them? ive been told one is on my bulkhead new the widow wiper motor but there isnt.
Please can any one help me.
Posted 06 November 2007 - 02:58 PM
Posted 06 November 2007 - 03:00 PM
Posted 06 November 2007 - 03:06 PM
Do not get the flasher unit confused with the square shaped relay in the engine compartment!!
Posted 06 November 2007 - 03:17 PM
Posted 06 November 2007 - 04:23 PM
A replacement costs 15 quid, so sod that until the next MOT.
I'm lucky that it hasn't upset my indicators..........yet.
Posted 06 November 2007 - 10:37 PM
the only thing thats got me worried is that the hazzards effect the indicators in such a bizzare way and i still cant find the second flasher unit which is supposed to be in the engine bay on the bulk head.
p,s just fitted a nice little 12" mountney steering wheel it feels real good spining it quick and going round bends like a demon. just need full resto buckets, brakes, cage and 1.6 turbo'd K series engine slapped in the front good job there are lots of 416i low millage rovers going cheap.
Edited by Bigman_small_car, 06 November 2007 - 10:54 PM.
Posted 06 November 2007 - 11:33 PM
Posted 14 June 2012 - 02:39 PM
Was just doing the indictaors and hazards this weekend on my mini. As alreay sadi the flasher unit is definatly the cylindrical unit located somewhere around the steering coloumn or behind the dash in front of the driver. With wiring help consult the haynes manual although the diagrams are god awful and extremely hard to look at and view they are accurate as i found this weekend when i did about 90% of the wiring on my mini. <img src='http://www.theminifo...t/whistling.gif' class='bbc_emoticon' alt=':-' />
What is this square shaped flasher in the front then???
Edited by M1N1 C00P3R, 14 June 2012 - 06:43 PM.
Posted 14 June 2012 - 05:38 PM
Posted 14 June 2012 - 06:51 PM
I thought the square flasher unit was the hazards flasher unit, but is says differently above!
Posted 03 July 2014 - 08:49 PM
My 1987 mini indicators stopped working.I have posted a comment on Chrissyw. I have now got the indicators working.
Posted 05 December 2015 - 04:02 PM
Hi,
i cannot seem to find anything on this i was wondering if someone has had the same problem and knows how to fix it or could point me somewhere its been mentioned somewhere else.
I have replaced the award switch as i have had that common problem, however my indicators have bee n working for a while now but all of a sudden have stopped, then started for about 5 mins and then stops again.
Thanks,
Jordan
Posted 05 December 2015 - 04:16 PM
The hazard flasher is usually under the dash near clock wiring Its marked 21 X 4 which means 4 lights at 21 watt .
Posted 07 December 2015 - 09:53 PM Best Answer
Thanks,
