I Just Broke Down!
Posted 26 November 2007 - 06:03 PM
When he got here, we tried to use leads thinking it might be a dead battery (even tho all my lights work) and that didnt work. In a last effort we tried to bump start it but in reverse, and got it going!!!
I managed to drive it all the way home (about half a mile) and turned off, tried to start again and not even any noise happens now. My friend said this is probably the starter motor.
Just wondering if anyone can confirm this before I go and buy one.
Many thanks in advance
Posted 26 November 2007 - 06:06 PM
cant help with the engine trouble
Posted 26 November 2007 - 06:09 PM
[EDIT] Is a stepper motor the same name as a starter motor? When I went to the rolling road, the guy pluged his computer in and it came up with stepper motor falt, but he said he seemed fine.
Edited by Bevan, 26 November 2007 - 06:25 PM.
Posted 26 November 2007 - 06:33 PM
Posted 26 November 2007 - 06:36 PM
Come to think of it, good thing i didnt break down yesterday in kent! thats a long way from home!
Posted 26 November 2007 - 07:40 PM
Duff alternator.
Duff starter.
Duff wiring with any of the above.
Take your pick!!
Posted 26 November 2007 - 07:45 PM
Posted 26 November 2007 - 11:05 PM
its always been the case with me that if i clean and re-grease the starter gear it will work but only last about 2months is before the problems come back...
hope this helps
Jim
Posted 26 November 2007 - 11:20 PM
I Just Broke Down!, Need some advice
Chin up, get a grip, it will be better in the morning, every clouds got a silver lining......
Seriously. Before shelling out for a new starter try cleaning all the electrical connections and earth points on the battery, solenoid, starter motor and engine to body shell earth strap. The starter pulls a huge currant and any rust / carp on any of the above can cause problems, so getting all the connections nice and shiny can make a difference.
Edited by pogie, 26 November 2007 - 11:22 PM.
Posted 26 November 2007 - 11:35 PM
Posted 26 November 2007 - 11:46 PM
Posted 27 November 2007 - 10:05 AM
Posted 27 November 2007 - 10:50 AM
However, if Injection cars still use a solenoid; if you turn the key to turn it over and you can hear a click, thats the solenoid working. This means either the starter isn't get enough juice to turn over, isn't earthed properly, starter is FUBAR, or engine is binding somewhere.
If you don't get a click then either battery is completely FUBAR, or solenoid is FUBAR, or no juice getting to solenoid.
Posted 27 November 2007 - 12:57 PM
although first clean all the earths up, test the battery with a multimeter or try a jump on it to see if its low voltage.
also get some one the turn the key in the ignition and hit the solinoid this can sometimes unstick them short term
Posted 27 November 2007 - 07:13 PM
Where abouts can I find the stepper motor and what do they look like? I dont know if this should be rite, but when my car idles (about 800 revs when warm) it does seem to be a bit jumpy, not much but sometimes it feels like it wants to stall but never does. I just thought its because its old and has always done that, does this sound like a problem too? Could this be related to the stepper motor?
[EDIT] When I say refit it all back, I mean taking apart the starter motor and refitting it all back together, not fitting it back to the engine.
Edited by Bevan, 27 November 2007 - 07:16 PM.
