my 93 spi cooper has an annoying habit of when you let off the throttle the car seems to start to back off then all of a sudden surges on for a split second.
any ideas what could be causing this?
also i think i have started to settle upon a specification for my rebuild.
looking for comments if possible.
+20 thou overbore using 21253 Pistons
Regrind, Balance and Polish Crank
Balance Rods
Centre Main Strap
Recondition Current ST3 Calver Head and work chambers to approx 23cc to give sensible CPR and allow use of normal 95ron unleaded
Duplex Timing Gear & appropriate offset key
New Followers
Kent MD274 Injection Cam
Standard Sintered Rockers
Lighten & balance std flywheel
enlarge throttle body to 44mm
Port inlet manifold
rebuilt box with 3.44 diff with central pick-up & uprated diff pin
maniflow lcb with lambda takeoff in y piece
twin box maniflow CAT back system
De-CAT Pipe
k&n induction kit
Edited by minimadmotorman, 29 November 2007 - 09:11 AM.
