I have just replaced my written off MINI with a 92 MINI city, good solid vehicle and i'm very happy with it,right price,right condition etc.
one problem which occasionally rears its head is that at low speeds the car will jump out of second gear, I'm thinkin its probably the selector forks.
Has anyone experienced anything similar, if so is it an expensive fix?
any input apreciated.
Jumping out of 2nd gear
campfreddie
, Feb 02 2004 08:31 PM
2 replies to this topic
Posted 02 February 2004 - 08:31 PM
Posted 02 February 2004 - 09:26 PM
Before rippin the 'box appart to see if anythin is worn out, check that the engine and any other steadys you've got fitted are all tight and that the bushes are all good too. If there is any excessive engine movement it can pull it out of gear. Also check that the engine mounts are good too and the 2 rubber bobbins on the gear linkage by the gear stick are ok.
If this doesnt cure it, looks like the engine is gonna have to come out
Posted 09 February 2004 - 10:18 PM
a freind of mine has no second gear at all they are prone to wear out v quickly and this is on a std 998, if its to do with bushes then it should do it in 4th too
