Wont Rev
Posted 14 December 2007 - 06:04 PM
Posted 14 December 2007 - 06:20 PM
Posted 15 December 2007 - 02:00 PM
I may be a few things so we could ideally do with a bit more information.
Have you checked the usual maintenance items?
Posted 10 January 2008 - 04:56 PM
I have read a few posts here but have not found any answers as of yet thats why i have started a new topic
Simon
Posted 10 January 2008 - 05:02 PM
I had no computer there for a couple of weks cause i left it down the country whilst visiting friends.
Regards
simon.
Posted 10 January 2008 - 07:09 PM
Its hard to explain really. It will start up with no problem but just spits and farts for awhile then once warm after a few mins it runs grand just wont go past 2500 revs. Ask me some specific questions and i will try and answer them the best i can because i am a bit slow really.
Regards
simon.
Hi Simon,
In response to your enquiry, Yes I did fix it. I changed the entire wiring loom and ecu for that of an earlier cooper. Its still going now. I never found the cause though, I can only assume it was an ecu fault.
Regards
John.
Posted 10 January 2008 - 10:17 PM
Battery drain could be anythig. if its anything to do with the Injection system its either or the ECU or Relay pack. The ECU can be tested at specialist garages.
As for your problem with overheating cats and running problems, with it being a 92 spi, first place i would look is the throttle switch. Make sure the carpets are not in the way of the throtle pedal and switch. If they are clear, the switch may well be faulty. Replace the switch, they are about £14 sor so from MiniSpares.
Do not drive the car untill this is fixed, and if you have been the cat may well have melted and is now adding to the issue because it is partialy blocked.
Hope that helps
Posted 30 January 2008 - 11:12 PM
IS there any reason this worked for a couple of mins and then reverted back???
Posted 07 February 2008 - 02:42 PM
Anyone got any ideas?
Posted 07 February 2008 - 04:25 PM
Posted 08 February 2008 - 11:54 AM
Can someone explain what happens when a cat melts?
Why it happens?
And, how can you tell if your cat is melted?
Posted 08 February 2008 - 04:29 PM
Posted 08 February 2008 - 04:51 PM
I'm curious. I've read about the possibility of melting a cat. I thought cats were porcelain.
Why it happens?
The throttle pedal switch on the early SPi was there to tell the ecu that the engine was idling. As the driver depresses the accelerator pedal, it then tells the ECU that the engine is now in a driving condition. If the switch is stuck and telling the engine it is idling and the driver depresses the accelerator, the engine speed rises, but the ECU is trying to maintain 850 rpm. The ECU backs off the stepper and if the engine speed does not drop, the ECU then backs off the ignition advance. It is this situation, high revs and retaded ignition that causes the inlet backfire, combustion in the cylinder is incomplete and continues in the exhaust where it melts the cat
Cats do indeed melt, the matrix is so thin that when in this situation, the ignition retards so much, combustion takes place in the exhaust the cat acts like a mantle of a gas lamp, its kind of a flame trap. There is a term my engine mapper uses which i found a little funny, Thermo Rich, lol. As the cat matrix is so fine it doesnt take mutch to melt them when abused. It is quite common in the motor trade. It partialy or totaly blocks the exhaust thus asphyxiating the engine.
http://www.car-sound...4failures02.asp
Posted 12 February 2008 - 11:33 AM
I think now that there may be a problem with that little pipe thing that fits onto the ecu between the two connectors.
Any ideads
Posted 12 February 2008 - 11:53 AM
Good luck with it, Simon.
And thanks to Sprocket for the explanation about cats. I'm learning heaps on this forum!
