Well im running a standard radiator at the moment and in winter it stays at the halfway point but in hot weather it goes another quater higher and if im in traffic or motorway trips (all weather) on the motorway it sometimes goes near the red. Is that normal??
Radiators
Mr Clubman
, Mar 17 2005 11:03 AM
38 replies to this topic
#31
Posted 17 March 2005 - 09:15 PM
#32
Posted 17 March 2005 - 09:21 PM
Hmmm, sounds like you may need to flush your rad through, what size engine you got?
#33
Posted 17 March 2005 - 09:22 PM
Its a 998 and i flushed it in november.
#34
Posted 17 March 2005 - 09:26 PM
Hmmm, I'm not sure with that, I don't think it should be getting up to the red area, but maybe in traffic in the heat it will?!
#35
Posted 17 March 2005 - 09:27 PM
I am buying 2 MiniSpares rads to keep my engine cool. Playing with the idea of electric water pump as well. Runs 1 (but will be changeing to 2) electric fans at the moment.
So quick answer would be: MiniSpares 2 Core Rad.
#36
Posted 17 March 2005 - 09:31 PM
Well its been near the red once, it did go 100 odd miles at 65 lol. Main motoways, its about a quater and another half a quater above the half way. Think the radiator may need replacing or somthing else. Will find out eventually tho.
#37
Posted 17 March 2005 - 10:38 PM
iv always had a std rad and have never had any problems even after a good ragging. only time it went a bit high was when the water needed topping up
#38
Posted 18 March 2005 - 02:10 AM
i'd check your thermostat as well Jackman, it might not be the rad
#39
Posted 18 March 2005 - 06:06 AM
still think you should go for a front rad, theres enough room in the clubbie with a bit of work on the front panel
