Cv Boots
Posted 18 December 2007 - 08:43 AM
I have read that other have had problems with the CV Boots splitting due the angle of the drive shaft on the passenger side. Spoke to Z cars who now recommend using 20mm engine mounts to lower the engine. This has been done and new boots fitted and 100 miles later top boot split and thrown the grease all around engine bay!!
Any ideas on what to do don't want to just fit another boot and hope it dosent split, is there an altenative fitting/boot type?
Andy
Posted 18 December 2007 - 09:04 AM
There are high angle CV boots available, but I'm not sure if it will cover your application and how much use they would be on a car that does more than a few miles
David
Posted 18 December 2007 - 06:15 PM
Edited by jacko299, 18 December 2007 - 06:17 PM.
Posted 19 December 2007 - 09:51 PM
we have tried all sorts of different boots but just cant seem to get them strong enough
the original ford boots were very tough and didnt split no matter what you did but they have stopped making them anymore so it looks like we will have to rejig the rear end a bit to suit which is a bugger really as if we could get good boots its not an expensive thing to fit,an exhaust is going to cost many times that.
if you can bear with me a few weeks we will beat this problem
chris
Posted 19 December 2007 - 10:08 PM
Posted 16 May 2008 - 09:54 PM
My passenger outer boot has split and I will need to change it for the MOT in a couple of weeks.
I'd rather sort it properly if I can rather than a quick fix.
David
Posted 17 May 2008 - 06:25 PM
Andy
Posted 15 June 2008 - 01:58 PM
The fix that you are speakin of chris will this cost us as our kits are older and have the fault of the driveshaft angle and the new ones wont ,
im on my 3rd boot now , and differnt make, its getting annoying..... always the same one, and ive lowered the car too.....
HELP
Posted 16 June 2008 - 02:12 PM
Posted 21 June 2008 - 01:18 PM
I will hopefully fitt them this week. Cab anyone advise how best to remove the drive shatfs please? do you need to unbolt the hub and remove brake caliper etc or will they just slide out with the shock obsorber disconnected.
Regards
David
Edited by xtr2turbo, 22 June 2008 - 01:49 PM.
Posted 10 July 2008 - 04:12 PM
remove wheel
undo the big nut on the end of the driveshaft, left hand side is reverse thread by the way......
on the wishbone, unbolt the inner (engine side) rose joint,
leave the outer rosejoint, as you can pivot the wishbone nicely without removing it,
undo the top suspension nut and the anti roll bar nut,
tap the end of the drive shaft with a soft hammer and pull wishbone outwards
the driveshaft will go threw the hub,. and out,
easy
you will not need to remove the brake lines and handbrakes lines, (on mine anyway i didnt,) as long as you didnt do them to tight like a silly boy.,
still waiting on this fix from z cars as mine just did it again and im completely hacked off with it now
spoonz
Posted 10 July 2008 - 04:20 PM
I have bought some super flexible neoprene boots. You can actually stretch them with a special tool to fit the small end over the whole boot!!
Regards
David
Have you fitted them yet? What are they like?
Posted 13 July 2008 - 10:26 PM
Not fitted yet. Hopefully will be next weekend
David
Posted 15 July 2008 - 08:03 AM
When will this be looked upon chris ?
spending more time taking the car apart instead of driving it.
Posted 15 July 2008 - 10:52 AM
Spoonz what type of boots are you using? Are they neoprene flexible or rubber?YAY THE OUTER ONE HAS GONE NOW AND I ONLY JUST REPLACED THE INSIDE ONE!!!
It is a pain though
David
