had the air filter off today to see if i could see where my stong scent of fuel was coming from, looked around and couldnt see any leaks. started it up and when u first blip the throttle you can see some sort of little spay come back up the elbow on the back of the carb. i presume this is fuel as i hope it isnt oil lol. any ideas what could be causing this?
rob
Fuel returning
rob mini
, Mar 19 2005 04:51 PM
4 replies to this topic
Posted 19 March 2005 - 04:51 PM
Posted 20 March 2005 - 11:39 AM
what sounds like is happening is the fuel is being drawn towards the airfilter housing and not towards the engine, this is mainly caused with incorrect timing, or incorrect valve clearances.
have you done anything to the car or has it been running badly
Posted 20 March 2005 - 06:23 PM
it feels flat as a fart and im sure theres more power in her. tappits have all been set recently if thats what you meant with valve clearences
rob
rob
Posted 20 March 2005 - 11:14 PM
Could be a slightly blown head gasket between siamesed cylinders. That happened to me once and this was one of the signs. If it has blown here there'll be no other signs like water in the oil or anything. Do a compression test to find out.
Posted 21 March 2005 - 01:55 PM
will do a test 2moro evening, all headgasket etc is new though and hasnt ran hot at all since i put the new head on (unleaded). been told from somewhere else running low dashpot oil could cause this?
rob
rob
