overheating?
Dom
, Mar 19 2005 05:06 PM
14 replies to this topic
Posted 19 March 2005 - 05:06 PM
what causes overheating?
because i may have a problem with my mini.
Posted 19 March 2005 - 05:53 PM
Water pump ok?
Blocked/damaged radiator?
Fanbelt slipping?
Timing out?
Fanbelt slipping?
Timing out?
Posted 19 March 2005 - 05:59 PM
and lack of water !
Posted 19 March 2005 - 06:14 PM
Thermostat?Water pump ok?
Fanbelt slipping?
Timing out?
Broken fan?
I think you need to be more specific - what's the problem, when does it happen, that sort of stuff!
Posted 19 March 2005 - 07:33 PM
well i wasnt too sure if it was a problem.
i thought it had been overheating as during the day my fan was constantly on but was that due to it being a hot day or was there a problem? i had a look at the fan etc there doesnt seem to be a problem.
ive just got back from a drive, its a lot cooler now and there was not problem, could it just be because it was a hot day?
i didnt notice this last summer, one day it was extremely hot and the fan came on but it seems odd that at this time of year it comes on.
Posted 19 March 2005 - 09:14 PM
I have a cooper carb like you and have owned mine from new
When i first had mine the fan never came i even tested once .
then after about 5-6 years it started coming on if the temp went above 1/2 way
about 12-13 years old it started coming on at 1/2 way
now its 15 years old it comes on just under 1/2 way
I think the thermostat is on its way out and has been doing so slowley
maybe at 18 years old i will need a new one
Posted 20 March 2005 - 08:51 AM
no 1990 cooper carb has 2 fans engine driven one and electric fan in wheel arch .
Posted 20 March 2005 - 09:04 AM
i thought it had 2 as one is always on and then the other kicks in when it gets over halfway.
i think you are right 'bungle' the thermostat must be on its way out.
Posted 20 March 2005 - 06:43 PM
yeah, replace thermostat, mine went and it overheated in snow! lol. had been meaning to do it for ages! but be warned, be prepared, have all the bits and leave a good day (pref 2 just incase) as it can be a real b*&£h to do!! the housing and studs corrode and are pain to get out. its ok to get the stunds out the head though, so just replace it all!
Posted 20 March 2005 - 07:41 PM
I ment the electric stat for the fan not the water one if its only the fan coming on early
Posted 20 March 2005 - 09:36 PM
err... now confused, can someone elxplain
Posted 20 March 2005 - 09:49 PM
theres one stat in the head replace this one if the water temp is high
and theres a electrical stat for the fan replace this if the fan comes on to soon
Posted 20 March 2005 - 11:20 PM
It's a thermic switch and it could be in the thermostat housing or in the bottom of the rad depending on exactly which car you have.
If your engine thermostat was dodgy then you'd get other signs like an incredibly hot heater or a boiling rad. Keep an eye on the temp gauge and if the gauge works and doesn't go above normal but the fan still comes on then you need a new thermic switch.
Posted 20 March 2005 - 11:32 PM
it screws in to thermostat housing near the top look for the two wires coming out of it .
