Spi Will Not Start
5 replies to this topic
#1 MiniSal
MiniSal
  • 219 posts
Posted 24 December 2007 - 02:47 PM
My husband and his friend changed the cam on his 1995 spi and now the wretched thing will not start. There is power to the coil, but no spark from the coil - any ideas would be greatly apprecaited.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,129 posts
Posted 24 December 2007 - 02:55 PM
If there's power to the coil pack.... but nothing coming from the coil pack,... that tells me that the coil packs broked but i think you've probably checked that! :-
SPi's and MPi's are run of pure black magic so i'm afraid i can't help... have you tried posting this in the 'injection' section? might be something in there already :-
#3 Jammy
Jammy
  • 25,397 posts
Posted 24 December 2007 - 04:28 PM
Moved to Injection.
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 24 December 2007 - 07:46 PM
Has the distributer been set up correctly?
was the flywheel removed and if so was the crank sensor removed before the flywheel?
If the fuel pump primes and you dont get a spark but you do get a squirt of fuel, the crank sensor is good and its down to the set up of the distributor.
If you dont get a spark or a squirt of fuel the crank sensor is suspect.
If you dont get the fuel pump to prime when the ignition is switched on, there are other issues as well.
#5 MiniSal
MiniSal
  • 219 posts
Posted 06 January 2008 - 04:10 PM
They have spent the day looking at this car and it still won't go. Have you any other ideas please ?
#6 Sprocket
Sprocket
  • 7,266 posts
Posted 06 January 2008 - 06:01 PM
Give us some more clues
What out of the above has been done?
