Won't Idle
powermadcoop
, Dec 24 2007 04:30 PM
13 replies to this topic
Posted 24 December 2007 - 04:30 PM
hello.i have a 92 cooper spi but don't know if injection has any relevance here. For some reason my car won't idle.its a bit funny on idle at start up but manages it. If i rev its ok but when it goes to 1000 rpm it just goes past and stalls. Iv'e not so long back put on new dizzy cap and rotar arm.was fine yesterday on rolling road! Any ideas? I've cleaned all leads and inside dizzy...
Posted 24 December 2007 - 08:24 PM
Put some fuel in it
Again, sounds like the stepper needs tuning correctly.
I seem to remember you posting a while back about idle problems, did you ever get anything done about it. And what place does rolling road tuning on a Sunday Did they adjust anything?
Posted 24 December 2007 - 08:45 PM
my daughter is idle !
Posted 24 December 2007 - 09:22 PM
Random!
Posted 25 December 2007 - 12:52 PM
yeah i did have a problem with it but it just sorted itself out. This has only happened since i've taken my old dash out and put my new one in.all i've done is change my switches to toggle ones and a bit of wiring to fuse box.doesn't always start first time now either but usually does.i meant saturday for the rolling road too.came out at 73 so dead pleased with 72 torque.he said ran really well at minisport. Its got new fuel filter too.if it is the stepper motor didn't you say you needed a proper diagnostic to do it? Where round us up north can do it ?i've read the stepper motor operation thread and read all the haynes stuff about indexing it but not sure how to do it still.cheers!
Edited by powermadcoop, 25 December 2007 - 06:09 PM.
Posted 26 December 2007 - 04:38 PM
Halifax isnt NORTH mate....come up here to where its cold...lol....... I can do fault codes and stepper set up if you want but im Nr Darlington if your mini can make it that far.
DaveRob
DaveRob
Posted 27 December 2007 - 09:04 AM
yeah itll make it easy
whats your post code mate just so i can aa route finder it...
Posted 27 December 2007 - 09:22 AM
You were just waiting for a thread like this to use that line!
Posted 27 December 2007 - 10:20 AM
PMed
Posted 27 December 2007 - 03:05 PM
suppose ill add this in whilst ive some time!
when it starts its a bit "gluggy" and is until i give it some res at which point its ok then itll rest at idle and hopefully not stall!
another thing ive noticed is that low down as in below 2000rpm it wants to die and kind pulls back if u put ur foot down but anything over that its fine and as fast as ever!
are we still thinking it might be the same thing?
if its not will the fault finder find it?
Posted 02 January 2008 - 02:11 PM
have you checked the vacum pipe on the underside of the inlet manifold as the 90 degree conectors split from the exhaust heat
and and then the ecu loses it vacum feed so will not idle
Posted 02 January 2008 - 08:33 PM
Powermadcoop dropped by the other weekend. FCR pluged in.....fault on MAP sensor. Pipes checked and sure enough MAP pipe had fell out under the ECU... cleaned ... pluged in and tye wrapped on... fault cleared. Lost motion gap set and all faults cleared and Mini idling .......job fixed.
Posted 03 January 2008 - 01:06 AM
Top Man
Posted 03 January 2008 - 09:11 AM
thought id posted back in here... anyway yeh its fxed......robs a sound guy and ery helpful!
im going to donate some £ to air ambulance north for him for the help too
