lights
11 replies to this topic
#1 frostie
frostie
  • 343 posts
Posted 22 March 2005 - 04:52 PM
hi everyone,
just started checkins a few things on my mini for the MOT next week...n for sum reason my headlights dont flash!they turn on...2 levels of brightness...and then full beam wiv the left stalk forwards...but no flash when pulled back towards me :P
any ideas why?
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 22 March 2005 - 07:24 PM
The headlamp flash is on a different circuit than the main lighting and shares a fuse with the horn so try looking into the horn circuit.
#3 Boab
Boab
  • 1,610 posts
  • Local Club: E*S*M*O*C
Posted 22 March 2005 - 08:13 PM
Do you have an after market steering wheel, if so I have been informed that this effects the flashing unit and the auto switch off for the indicators. Or am I talking *****
#4 frostie
frostie
  • 343 posts
Posted 22 March 2005 - 08:21 PM
bingo!! i haven't got a horn!!lol i checked around and i cant find it!is it still behind the grille on later models? 1993?
where is the fuse? is it in the fuse block on the bulkhead....if so which one?
thanx
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 March 2005 - 08:23 PM
I think you talking *****
#6 frostie
frostie
  • 343 posts
Posted 22 March 2005 - 08:26 PM
erm....hopefully aimed at bigbadboab :saywhat: :sad: lol :tongue:
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 March 2005 - 08:28 PM
yes . . changing steering effecting flasher ?
#8 frostie
frostie
  • 343 posts
Posted 22 March 2005 - 08:47 PM
any ideas about horn and fuse location?
#9 JamesM
JamesM
  • 415 posts
Posted 23 March 2005 - 02:29 PM
Main fuse box, I believe second or third down, check your heated rear window as well, pretty sure that is on the same circuit.
My lights won't work at all on my Clubby that is until i leaft it on the road last weekend, I can back in the Cooper only to find the lights on all day. Then I must of parked the Cooper to close to the Clubby because now he thinks it is funny to put turn onto sidelights when I put on full beam. No spots or headlights.
It all went very dark.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 March 2005 - 06:01 PM
Any chance you could say that again in English?
As for the fuses, it's fuse 2 in the main fuse block. It doesn't supply the heated rear screen, but it might be running the brake failure warning and the stereo.
If it's not the fuses then check the connectors in the circuit, particularly the ones on the bulkhead and under the steering column.
#11 frostie
frostie
  • 343 posts
Posted 24 March 2005 - 10:45 PM
cheers i'll check the fuse 2moroz....one more thing....i really dont think i've got a horn!lol i've checked behind the grille where it should be and it isn't there?will the flash still work if the horn is disconnected?
#12 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 24 March 2005 - 10:52 PM
it should do, but you'll fail the MOT on not having a horn instead....lol
