Spi K&n
#16
Posted 04 January 2008 - 03:43 PM
#17
Posted 04 January 2008 - 03:46 PM
#18
Posted 04 January 2008 - 05:35 PM
Still got problems with idle.
I have been swapping my air filters over and this is the difference.
Standard SPI air filter
K&N air filter
Im really stuck with what to do!
[EDIT] This is when the car is fully warmed up too
its worth noting that now the engines breathing suply is improved the characteristics of the engine will change on the spi it is possible to adjust the idle using the idle screw which is foudn on the back part of the trottle linkage which is conected to the stepper motor, i have used both 57i k&n and the pannle filter i found the insert filter if u drill the air box and use a dremle or alike to smooth out the ridges it will give u more power and be a little quiter too .
#19
Posted 04 January 2008 - 06:22 PM
have you tryed fitting the standard filter ( all runs well) and then fit the K&N using word for word instuctions like MiniFrank did?
#20
Posted 04 January 2008 - 07:20 PM
K&N air filter
DO NOT UNDER ANY CIRCUMSTANCE ADJUST THIS SCREW!!!! unless you have access to a diagnostic and can see the stepper motor steps!!!!!!
I think there is underlying problems with the gereral tune of the idle air, stepper motor and throttle cable adjustment. I recomend you find the best garage you can and get a diagnostic and tune done on the Idle air and stepper after following the Haynes manual word for word on how to adust the throttle cable.
Fitting a K&N filter is a simple task if the instructions are followed to the letter. any issues are usualy down to a problem else where. The injection system will normaly adjust the idle speed to sit at 850rpm when warm, stepper steps should be at around 40 at idle. I suspect yours is at 0 and well out of tune probibly because some one who didnt know what they were doing adjusted that little screw. The only satisfactory way to correct this is by using a diagnostic. You could 'Yeh Ha' it and adjust this little screw, untill the idle drops, then a little more so that the stepper then moves to push the throttle open and keep the idle at 850rpm. Thats is if the stepper is functioning correctly and to determine that you need the diagnostic.
Get a diagnostic connected
#21
Posted 04 January 2008 - 08:31 PM
have you blocked the red pipe up?
Red pipe has been blocked with the screw, and I have moved, and even taken away the cold air feed and no difference. I have always expected something to be up with the the idle speed as its always been a bit lumpy when at about 850-950, it doesent sit bang on and the needle with bob up and down. Also when driving, if the car is moving at speed and I break, as im comming to a stop the car will often jump up to about 1500 revs, as soon as the car is stationary it will slowly drop down.
I may well have to take it to my local rolling road, the only place I really trust.
Edited by Bevan, 04 January 2008 - 08:32 PM.
#22
Posted 04 January 2008 - 09:37 PM
#23
Posted 04 January 2008 - 10:28 PM
Another option may be to go up to mini sport for the day and see if they can help.
#24
Posted 04 January 2008 - 11:07 PM
#25
Posted 10 January 2008 - 03:45 PM
#26
Posted 11 January 2008 - 07:07 PM
Problem solved!
#27
Posted 12 January 2008 - 12:35 AM
