How much play is it SAFE to have in a wheel (front), up/down and front/back.
My left one is solid as a rock but the right one has maybe 1mm play at the edge of the 12" rim up/down, and maybe 2mm when holding from 3 and 9 oclock positions.
I know this is not good, but is this amount of play safe enough to drive it for a few months?
Play in hub
Pavel
, Mar 30 2005 08:41 PM
3 replies to this topic
Posted 30 March 2005 - 08:41 PM
Posted 31 March 2005 - 04:04 AM
Did u try to tighten the CV nut?
-ima
-ima
Posted 31 March 2005 - 09:03 AM
id check it over pavel, as it depends where the play is coming from!
Posted 31 March 2005 - 09:51 AM
up/down movement is usually a Balljoint, side to side 'rocking' is usually bearings..
ball joints are peasy to replace, just a bit time consuming!
