Hi,
Is there a special trick for fitting the Engine Stabiliser Rubber Bushes on a Mini with a servo (my Cooper). I had a little look and it's a bit tight for hand space at the bulkhead end.
Cheers. :sad:
Engine Stabiliser
Wesser
, Mar 31 2005 12:33 PM
3 replies to this topic
Posted 31 March 2005 - 12:33 PM
Posted 31 March 2005 - 03:23 PM
if your cooper is a later one with an ECU, then it is really tricky to get to anything that side of the engine...too much electronics black magic stuff for my liking )
i know it is a pain but the servo is not that tricky to remove if you are having problems
Posted 31 March 2005 - 03:30 PM
Yep it's a 97 with the ECU. So that's the "trick" then remove the servo !!
Now I can see why the last bloke didn't change it.
Posted 31 March 2005 - 04:07 PM
Get a mini mechanic to help
