Cylinder head weld.
Posted 31 March 2005 - 09:31 PM
Posted 31 March 2005 - 10:02 PM
my grandad was a mechanic on the humber lifeboat during the war , and he use to tell me lots of storys of repairs to keep the boat going as there were no spare parts . like welding heads and blocks , reparing cracks in heads and all sorts of bodges .
There was one story that he had to replace the big end bearings at sea with the other engine running beside him to get the boat home , no wonder he was deaf .
Posted 31 March 2005 - 10:48 PM
Posted 31 March 2005 - 10:53 PM
see " hi i'm marcus "
Posted 31 March 2005 - 11:13 PM
Posted 01 April 2005 - 01:04 AM
Welding cast iron is an art. It can be done with nickle rich welding rods, a lot of careful pre- and post-heating etc. If the damaged part of the head is NOT in the combustion chamber area, brazing is the prefered method of fixing cast iron.
Posted 01 April 2005 - 01:47 PM
Posted 01 April 2005 - 01:53 PM
Posted 01 April 2005 - 01:56 PM
Posted 01 April 2005 - 03:22 PM
The outer crack can certainly be brazed. If I had to guess, I'd say you ran the studs too deep and they worked like a wedge to split the casting. This is a great reason to use bolts of the "right length" instead of the studs. After brazing, re-tap the holes with a bottoming tap. Then determine (by dry fitting the parts) what the maximum safe stainless bolt length will be. Cut the bolts off if necessary to get that length less about 1/8" [3mm]. Make sure all the tapped holes have the same thread depth and that all the bolts are the same length so it won't matter which bolt is in which hole.
What concerns me is what appears to be a second crack visible in the first picture. It looks like there is a crack started adjacent to the hole nearest the through hole for the head stud. If cracked, that one will be harder to fix without warping the head. Regardless, once brazed, the head should be checked and most likely shaved flat again. Expect it to warp a little.
Posted 01 April 2005 - 03:32 PM
Thats just the casting line. The crack you see in the 3rd pic is all there is.What concerns me is what appears to be a second crack visible in the first picture. It looks like there is a crack started adjacent to the hole nearest the through hole for the head stud. If cracked, that one will be harder to fix without warping the head. Regardless, once brazed, the head should be checked and most likely shaved flat again. Expect it to warp a little.
Cheers DK, I will be asking my freindly welder guy to fix this for me. :grin:
