Mpi 2001 Cooper Misfire Help!
Posted 21 January 2008 - 10:37 PM
Easy we hear you cry -
The car has been to local mini garage no faults found
Changed Plugs? Done no difference
Coil Pack? Done no difference
Crank senor? Done no difference
Temperature sensor? Done no difference
Cam sensor? Done no difference
Lamba Sensor? Done no difference
Inspected Cat? Done no difference
Extra earth wire from body to engine? Done no difference
ECU Checked? Done no Faults!
Compression Test? All ok
Swapped fuel injectors? Done no difference!
Any sensor we can think of has been replaced with genuine mini part!
If anyone has any suggestions it would be very helpful! Have so far spent a fortune and no further on!
Posted 21 January 2008 - 10:40 PM
Note: the lines themselves may be okay, but the little elbows fail too.
Posted 21 January 2008 - 10:44 PM
Hi I have a 2001 mini cooper 1300 with a miss fire? Miss fire is intermittent and not always there, but when missfire happens feels like car is going to stall although it dosent! It sometimes back fires through the inlet manifold any suggestions?
Posted 21 January 2008 - 10:45 PM
What about your vacuum lines? Have these been checked for leaks?
Hi thanks for the quick response - but these have been checked and all ok????
Posted 21 January 2008 - 10:59 PM
What plugs you using? A friends had the similar type and it was down to the type of plugs that were used.
Posted 21 January 2008 - 11:01 PM
Hi - Denso plugs as per guidance chart? and gap to manufactuers recommendations!
Posted 21 January 2008 - 11:05 PM
Posted 21 January 2008 - 11:22 PM
Hi not sure. what difference would this make? thanks elsieAre they a resistor type?
Posted 21 January 2008 - 11:24 PM
If you get the code off the plugs ill check.
Posted 21 January 2008 - 11:31 PM
None resistor type will overheat the coil (i think that the right away around) causing misfire problems.
Hi Thanks for that will check although dont think it fits - missfire will happen completly randomly - ie from cold or warm - can be driving and the car will start to missfire complete journey and leave for 15 minutes and then completly fine - or fine from cold when warm starts to missfire or from cold will missfire - only real difference is the fault seems to becoming more permanent? and fault still present with old and new plugs!
Vehicle has only 14,000 miles on clock?????!!!!!!!!
Thanks will check the type though
elsie
Posted 22 January 2008 - 01:42 AM
When you say miss fire, does it hesitate badly under acceleration?
It would be an idea to go for a drive with a passenger, while the diagnostic is connected, that way you can see wath the ECU is doing when it does it. Then you can narrow down the issue
Posted 25 January 2008 - 08:33 PM
Posted 05 February 2008 - 08:10 PM
Posted 05 February 2008 - 09:44 PM
A new set of HT leads, new plugs and finally swapped over to a K&N filter and everything is good.
Posted 06 February 2008 - 05:25 PM
