im after some rings for hepolite 2125 pistons, i got them from morspeed and managed to break on oil ring upon fitting. Iv tried local places for another one with no luck and tyred xrm, morspeeds supplier but the send the wrong rings :sad:
any help at all would be apreciated
+60 rings
TimS
, Apr 01 2005 09:56 AM
5 replies to this topic
Posted 01 April 2005 - 09:56 AM
Posted 01 April 2005 - 10:14 AM
I have a set of part used +60's which I use as spares for the 21251 pistons (LC), which ring you after, and I'll see it I have a decent one.
Posted 01 April 2005 - 11:05 AM
im after an oil ring, like the one beow, its a cone piece rings with a srping behind it
Posted 01 April 2005 - 11:32 AM
fek, them is old rings, oil scrapers are normally 3 or 4 piece items with a spring and two thin scrapers... piccie below...
Have you checked the rings for wear and fit in the bores ? may be an opportune time to replace all the rings.. ? last set cost me 34 notes.
Posted 01 April 2005 - 02:21 PM
they are brand new rings, and its a frezhly rebored block! i got sent some more rings from XRM aring supplier but they are the wronmg type for the psiton, and with being at uni its beena bout a month b4 iv been able to try to fit them and they are too big width not dia.
Posted 04 April 2005 - 08:21 AM
That's a bit of a blow, but if you want, I can drop the above into an envelope and send it on....
