Can anybody give me any info about where the vacum pipe from the brake servo connects? Does it connect to the air filter or carberetor or some where else ?
Alic
Brake servo help
alic
, Apr 01 2005 04:13 PM
5 replies to this topic
Posted 01 April 2005 - 04:13 PM
Posted 01 April 2005 - 04:20 PM
it connects to the intake manifold this is the bit between the head and the carb
Posted 01 April 2005 - 04:26 PM
The servo has been fitted to a 1981 mini, I presume i need to drill and tap to fit a tail piece to the inlet manifold?
alic
alic
Posted 01 April 2005 - 05:57 PM
theres usually a casting blank or a hole already if its an after market manifold! you could drill and tap a hole but its probably easlier just changing the manifold
Posted 01 April 2005 - 06:14 PM
You need to get the blank on the manifold faced flat, drilled out to 14.5mm and tapped to something like 5/8 unf (I can't remember exactly what the thread is but I have the tap in my garage so I'll check later on). Then the servo pipe fits with two sump nut washers and an oil feed banjo bolt. It sounds like a mixed bag of sizes and parts but that really is the genuine fitting.
It's a bit of a pig to do really and it probably is easier to fit an '89 on manifold.
Posted 01 April 2005 - 07:00 PM
Thanks for the replys people, Ive already indentified the blank. Ive got spare manifold 1983 so will try drilling and tapping tomorrow.
Ali C
Ali C
