i have just aquired some heavy duty tie rods and was wondering how you would go about setting them up? is there a specific way or do you just do it by eye?
cheers
adjustable tie rods
1976 clubamn
, Apr 02 2005 01:50 AM
7 replies to this topic
Posted 02 April 2005 - 01:50 AM
Posted 02 April 2005 - 06:08 AM
You take it to someone who has the equipment to do tracking and other suspension setup
#3 Guest_falk_*
Posted 02 April 2005 - 06:47 AM
yep...
as a rule of thumb adjust them to the length of the original ones before you fit them. next step then is as Pavel already mentioned to take them to a tracking setup place...
Posted 02 April 2005 - 09:52 AM
makes sence. cheers.
Posted 03 April 2005 - 08:43 AM
Ello , I found this little guide on the Minispares website. It should get you rolling till you get it set up in a workshop properly.
Posted 03 April 2005 - 01:23 PM
i set mine both completly equal as roughly to the std set up as i could, when measured it was found to be a +5degrees caster whihc is slightly more than the std but feels nice still! You may have a problem fiding places that will set caster, i found the bets place to try was BUSH tyres
Posted 03 April 2005 - 03:21 PM
I have literally just fitted a set of these, along with some 1.5 -ve camber bottoms. The handling is a bit i dunno, wierd, first of all i set the tie rod to standard length, and it was almost as tho it tramlines. So then i lenghtened the tie rod by 2 turns to decrease the toe-in angle which has made it slightly better, but it still pulls wierdly.
It drifts slightly to the left aswel, me thinks i need my castor doing properly!
Will be ringing round tomorrow to get somebody to do it.
Or is it just because of the camber, makes the handling perform differently?
#8 Guest_falk_*
Posted 03 April 2005 - 04:37 PM
the bottomarms makes it a little bit feeling like selfcentering stronger ('tramlining') have you got your tracking done after fitting all the parts? then this should be gone... :cheese:
