How easy is it to spray panels? From start to finish, as i have no experience whatsoever! Because i was thinking about buying a brand new bonnet spraying it solar red and spraying the cooper stripes on it. Is this doable as i have no previous experience with this?
Cheers people,
Ed
Spraying
MINImiser
, Apr 02 2005 02:16 PM
12 replies to this topic
Posted 02 April 2005 - 02:16 PM
Posted 02 April 2005 - 03:12 PM
before i forget cooper stripes are usually stuck on rather than sprayed i think.
not as simple as just spraying because youll have to sand down the old one, use primer, paint then prob. lacquer, sanding at various stages so youll need at least shedloads of different grades of wet and dry paper. And to get best results you'll need a small air compressor and spray gun and buy the paint plus cellulose thinners, or for a bonnet you could probably make do with aerosols so you wont need a compressor.
Just make sure everything is really clean around you, do it indoors (well, in a garage) make sure theres no dust, practice on scrap panels first and remember the preparation (sanding, filling etc) is at least as important as the top coat of paint.
Its not hard to spray paint but as with everything its useful to practice and above all dont rush, esp. on the preparation.
good luck!
good luck!
Posted 02 April 2005 - 04:47 PM
Or you could try and find a second hand bonnet the right colour , buy the stick-on stripes and save a lot of hassle
unless your mini is a special colour ?
Posted 02 April 2005 - 05:23 PM
minis look better with out bonnet stripes
Posted 04 April 2005 - 06:17 PM
Thats only because you dont have them on your cooper bungle
Posted 04 April 2005 - 10:44 PM
ya see im inbetween! cant decide whether they do look better with or without the stripes!
Posted 05 April 2005 - 07:35 AM
Why not go half and half - just have one bonnet stripe!
Or, get a spare bonnet and have one bonnet with stripes and one without and change them over when you're in the mood!
Posted 05 April 2005 - 10:51 AM
what sort of spraying are you looking at doing? just using cans or using a compressor! iid advise to have a read trhough a book showing how to spray first, i know haynes do one! this will give u a good start and save u money
Posted 05 April 2005 - 02:26 PM
Bit off topic (sorry) but i saw a cooper with both stripes on one side of the bonnet, looked really original and quite good imo
Posted 09 April 2005 - 07:15 PM
To be honest i wouldnt try to do the spraying yourself unless you have the equipment and experience, getting a decent finish isnt as easy as it may seem and im sure you want it to look good. If its only the bonnet you want spraying it wouldnt cost that much to get it done professionally (well not at the garage work at anyway, talk about a plug lol)
Posted 11 April 2005 - 09:40 AM
We all gotta start someware, the nack is enough paint to cover with no orange peel effect but not too much that it runs or sags, you can't buy experience or practice. If using a can treat it like a gun start it off panel then sweep onto the panel whilst paint stream is in full jet. Preparation is the key the paint sinks down to the metal so if the marks there in the start it's always gonna be there. Loads of books about it and even a bit in most Haynes manuals. Nothing like the buzz of getting a mirror finish on your own though.
Get a couple of cans and have a bash on a bit of scrap plate. Good luck Mate
Posted 13 April 2005 - 06:28 PM
agree with the above statement. Used to have stripes but removed them...
Posted 17 April 2005 - 05:47 PM
I managed to aquire a second hand rusty Mini bonnet, unfortunatly it is from an older mini so wont fit my car. I am hoping to spray this soon to practice and was wondering what i would need to do this? And also what type of paint is the easiest to use for a beginer like me?
Ed
Ed
