Best place to jack the rear
vasi
, Apr 02 2005 04:19 PM
10 replies to this topic
Posted 02 April 2005 - 04:19 PM
When a beam axle is fitted?
Posted 02 April 2005 - 04:42 PM
on the rear sub frame??
Posted 02 April 2005 - 04:44 PM
What rear subframe
Posted 02 April 2005 - 04:58 PM
Do you need the whole rear up or just one side, personally I would of thought a jack with a plank of wood on top under the rear seats would be best?!
Posted 02 April 2005 - 05:16 PM
can you get the jack under the beam ?
Posted 02 April 2005 - 05:46 PM
I cant get a plank of wood and a jack under the floor together, the car is too low. And the beam isn't wide enough to safely place a jack on.
Posted 02 April 2005 - 05:50 PM
ummmmmm thinking
Posted 02 April 2005 - 05:56 PM
what do you want to do? can you not put it on ramps? of if you want to take wheel off, use the origional jack and jacking point at the front under the door. how did you fit the beam if you couldnt jack it up?
Posted 02 April 2005 - 05:58 PM
I have one more idea, can you get the jack and a peice of wood under the boot?! (or is the beam in the way?!) If you can jack it up, then put axle stands with another plank of wood under the rear seats?
Posted 02 April 2005 - 06:00 PM
Hehe for this job I can borrow ramps as the wheels dont need to come off. Would be handy for future ref tho
Posted 02 April 2005 - 06:01 PM
Cross typing there sorry.I have one more idea, can you get the jack and a peice of wood under the boot?! (or is the beam in the way?!) If you can jack it up, then put axle stands with another plank of wood under the rear seats?
I'll give that a go tommorow...
