I ve got a cooper rsp h reg with a minisports stage 1,
i was just wondering if twin su "s made any differance with power and witch size would suit my motor the best,any idea s ta.
twin su"s?
The beans
, Apr 06 2005 09:22 PM
11 replies to this topic
Posted 06 April 2005 - 09:22 PM
Posted 06 April 2005 - 09:40 PM
good day!, in one of the mini magasine theve gone throught how to strip twin su's don and rebuild them etc, it says that with the right set up they can out perform a webber, this could cause insurance to rocket! lol but you mini will do to! my freinds just dropped a 1275 metro engie nin his mini and put twin su's on it! and it sounds grewat its not on the road yet though
Posted 06 April 2005 - 09:44 PM
dan with the big HIF carb we have on our minis twins wont do any more
spend sues money on some high lift rockers 1.5
Posted 06 April 2005 - 09:49 PM
cheers jeffers!! ill look on ebay to see if theres any cheap ones !
Posted 06 April 2005 - 10:15 PM
Posted 07 April 2005 - 08:02 AM
WOW! lol i think the carbs would be less on insurance than twin SU's
Posted 07 April 2005 - 11:15 AM
dans a old git so insurance is cheap :tongue:
Posted 07 April 2005 - 03:19 PM
Will twin SUs off an austin princess fit on a mini? Ive been given a pair apparently which had been recon'd, put on a mini and then found to be too scarily fast for the driver which is why she took them off, put them in a box and threw them in when i bought her car. Hmm i suspect BS here, esp with so much other highly suss stuff i was told about the shed. her dad: "Aint these minis got an A rated engine, which means you cant blow them up?i think they have!" Upon which i offered to blow the engine up for him to disagree... :grin: i think he means a series....
Anyway they didnt seem to want to fit earlier on when i tried. any thoughts?
Posted 07 April 2005 - 04:22 PM
"Standard" twin carbs for a Mini would be HS2s. Any HS2s off of anything could be made to work IF you have a Mini intake manifold and IF you change the mounting isolators for the float bowls so they will be level when installed. Of course, if they came off some non-Mini car you'll want to rejet them when you rebuild them. (Don't forget you'll also need the dual carb linkage(s), springs, and heat shields).
That said, setting up twin carbs is a PITA. Vizard and others lament the poor performance of 'most' twin carb intake manifolds. My car has twin carbs and I'll leave them on for originality. If I wasn't concerned about keeping my car original, I'd use a single larger carb jetted to work best with my engine. There are much better intake manifolds to choose from and a wealth of possible donor carbs.
Posted 09 April 2005 - 11:09 AM
Are fitting twin su's something you HAVE to tell the insurance companies?
Andras
Andras
Posted 09 April 2005 - 11:31 AM
Yep
Posted 09 April 2005 - 11:53 AM
The only good thing about twin carbs is they look good. They are a pain in the arse to fit, set up and keep in tune and balance. Dont bother mate, get an decent HIF instead.
