Okay I've been having a lot of problems with my engine lately.
It's a 1.3 Metro lump.
It used to have a poorly set up Weber downdraft carb, but it ran with it. Problem was it would bog down when revving (it was too rich)
I decided to change it to a HS4 setup, so I did. Changed manifold and carb and started the car.
It idles fine on choke, wants to die without it, and often dies at a traffic light.
At first it wouldnt rev, it would just stutter if you pressed throttle down completely. I leaned out the mixture a bit and it got a bit better, but still happens when driving.
When driving there is absolutely no low end power. If clutch is released below like 3-4k rpm, the whole car will shake and stutter because it doesnt have power!!!!! I have to keep it high RPM all the time!
Second problem I noticed is this: If I take the leads off (one at a time) the two spark plugs at either end of the engine (1 and 4), the engine stutters noticeably.. However if I take the leads of either of the two centre plugs there is hardly any difference in idle. I thought they might be the wrong way round but this is not the case!!
Third problem is my idle speed constantly changes.. It idles and every few seconds revs up a bit (not a lot) and then goes back. Could my carb need oil?
Finally the engine developed a really ticky noise on idle. I am completely stumped by this, since the timing was not advanced from before and yesterday I filled her up with some Super Leaded petrol... It seems to go away when I rev it up (but I think thats because the exhaust note overpowers it ). Could it simply be that something is vibrating in my engine bay?
Engine problems
Pavel
, Feb 09 2004 05:58 AM
2 replies to this topic
Posted 09 February 2004 - 05:58 AM
Posted 09 February 2004 - 09:19 PM
Sounds like you got the wrong profile needle in it mate, are you usin a standard metro needle, or is it one for a mini??
Could also be that the weber runnin so rich has washed the bores and f**ked the rings...
Posted 09 February 2004 - 09:35 PM
Some of those symptoms could be caused by an air leak in the inlet after the carb .
