will it need re syncronising ? (sp) and if so how ?
Replaceing The Battry In The Immobolizer Fob?
scottyegg
, Feb 10 2008 10:05 AM
3 replies to this topic
Posted 10 February 2008 - 10:05 AM
Posted 10 February 2008 - 06:53 PM
see the bottom of my "alarm" thread a couple of days ago...
cheers
Tom
Posted 10 February 2008 - 07:02 PM
when you go to replace the batt, while the old one is out, hold the both buttons down for like 10sec, then insert the new batt. when you get in the car, put the key to ignition but dont start. press the arm or lock button several times, that should resync the fob to the module. then unlock and start.
Posted 11 February 2008 - 09:20 PM
My mini owners book says:
1) Carefully prise the handset apart, start from the keyring end using a small screwdriver or coin.: Avoid damaging the seal between the two halves of the casing and do not allow dirt or moisture to get inside the handset.
2) Slide the battery out of its clip, taking care to avoid touching the cicuit board or the contact surfaces of the clip.
3) Press and hold each button in turn for at least five seconds to drain any residual power in the handset.
4) Fit the new battery, ensuring the correct polarity is maintained. (positive '+' side facing up). Finger marks will adversely affect the battery life, avoid touching the flat surfaces of the battery or wipe them clean before fitting.
5) Reassemble the 2 halves of the handset.
6) Unlock the car, then press the handset lock button at least four times to resyncronise the handset to the car. (you dont need to insert the key or anything like that)
The handset is now ready to use.
