Hey... wondered if someone may be able to help as I am out of ideas....
The car idles at around 1000/1100 normally but if I put my foot down for a while while driving then pull up to idle again it can sit at 1800!
I have replaced the carb with another, checked the needle is where it should be and everything is sitting flush, I have had 2 different accelearot cables and used both 10-40 oil and 3 in 1 oil in the carb, all to no avail.
Any thing to try/cure would be appreciated
TML
Idle
themanlegend
, Apr 08 2005 06:13 PM
3 replies to this topic
Posted 08 April 2005 - 06:13 PM
Posted 08 April 2005 - 07:09 PM
Could be an air leak on a gasket somewere or even a fault on the ignition system. Is it electronic or points?
Another thing to check is that the accelerator is running smoothly with no tight bends or kinks or getting trapped anywere. Is the pedal moving freely and not sticking too.
Posted 09 April 2005 - 10:02 AM
I have points, replaced them and set them but didnt tune anything, if that helps.
I will check the cable and condition of gaskets. thanks
Posted 09 April 2005 - 11:55 AM
Also, check that the vacum advance pipe is on ok and not split.
