now that my nice head is on my mini, freshly painted aswell, heater tap hole drilled, i was wondering where the temperature sender does..
as you see on the picture there is no drilling for it, so can anyone, with a metro engine, please put up a picture where it should be, not that im worried about overheating, well not yet anyway...
cheers,
now where did i put those twin carbs i have to fit today :tongue:
temp gauge sender unit
cowboy
, Apr 10 2005 07:57 AM
3 replies to this topic
Posted 10 April 2005 - 07:57 AM
Posted 10 April 2005 - 08:08 AM
do you mean the sender for the temp gauge as thats under the thermostat housing in the head
Posted 10 April 2005 - 02:28 PM
On lots of Metros (and some injected Minis) it screws into the same sandwich plate as the heater pipe comes out of. If you have drilled the heater outlet in the head I assume you aren't using the sandwich plate for the heater pipes so you won't have anywhere to fit it. You may have to drill and tap the head for it.
Posted 10 April 2005 - 04:55 PM
looks like i have to get the tap set out then.
that will have to wait until later
thanks dan
:cool:
thanks dan
:cool:
