Hi guys i've got myself a battery cut off switch, i'm guna put it in line with the starter motor. But where should i have it coming into the car? In the dash, through the floor or any other ideas?????
Any ideas would be great, thanks!!!!!!!!!
Kill switch
jimbo_edmondo
, Apr 12 2005 09:52 AM
11 replies to this topic
Posted 12 April 2005 - 09:52 AM
Posted 12 April 2005 - 10:01 AM
I have mine on the floor just in front of the drivers seat, as the makes it slightly harder to be hot wired. But then again a kill switch isn't too hard to get around anyway when you think about it. Is yours one where you can take the key out?!
Posted 12 April 2005 - 12:36 PM
In racing this may be called a "kill switch" but it's really a battery disconnect switch. An honest-to-God kill switch is usually part of the ignition system and the ignition system only. A kill switch is a single-pole/single-throw switch wired between coil (-) and chassis ground. You close the switch and coil (-) is left permanently hooked to ground, thus preventing any spark from forming to ignite the mixture.
As for the battery switch, I've heard of people mounting them various places on Minis. I believe one of the most common over here is tucked up in the tunnel near the shift mechanism. Fitting it there would obviously depend on the size of the switch, your exhaust system and the shift mechanism as they all want that space.
Posted 12 April 2005 - 04:43 PM
Yea it's got a removable key, surely if it didn't there wouldn't be much point on a road car? I think the floor would be the best option like Jammy because at some point i expect to buy a proper dash board an then this would mean i'd have to move it again!
So i'll have a look at where it is goin later on.
Posted 13 April 2005 - 11:01 AM
my wiring knowledge is C**p can you have a kill switch like an ignition switch...baring in mind my cars having bear mini(boom boom)mum i realistically could have all the lights etc bar indicators hooked up to different flick switches etc on dash and a key kill/ignition switch?????
Posted 13 April 2005 - 11:20 AM
Well in my car, there is the battery cut off switch on the floor, which you have to turn, then a switch for the fuel pump in the back (something not everyone has to do), and then a switch for the ignition, and the a button which hits the starter and away. Its great, theres like a start up procedure to the car, very much like a jet or something!!
Posted 13 April 2005 - 11:31 AM
not very good when you need a quick get away because some girl has found you with her boyfrend :tongue:
Posted 13 April 2005 - 11:32 AM
not very good when you need a quick get away because some girl has found you with her boyfrend :tongue: jammy
Posted 13 April 2005 - 01:05 PM
If I'm with her boyfriend iTs usually because he's just found me sleeping with his girlfriend/fish/sheep and he's trying to pummel me!!
Posted 13 April 2005 - 05:04 PM
HEH HEH sounds cool tho jammy, battery check, fuel check, ignition check, starter check, chocs away!
I'd forget somethin an think something was terminaly wrong with my car!!!!!!!!!
Posted 13 April 2005 - 09:51 PM
Oh I've forgot the fuel pump a couple of times, as well as leaving it on, then switching it off next time I go to use the car!!
Posted 16 April 2005 - 11:58 AM
Mines in the boot directly next to the battery...
Lee
Lee
