i've heard about 1330 and 1340cc engines, and i wondered if anyone could tell me what the difference is. And dont say 10. is it a stroked crankshaft?
what the differnce between 1330 and 1340
Leonard
, Apr 16 2005 11:45 AM
5 replies to this topic
Posted 16 April 2005 - 11:45 AM
Posted 16 April 2005 - 01:35 PM
There is no difference as standard, as people mistakenly call 1330's 1340....
A 1330 is produced by boring to +.060" and using the original crank ( 81.3mm stroke )
A 1340 is possible, but it's an 73.5mm bore with a short stroke (79mm), but these are rarer and v expensive.
Posted 16 April 2005 - 02:07 PM
ok thanks for clearing that up. im thinking of building a 1330 with sw10 cam and modded head as i mentioned in another thread. would a standard 1275 dizzy be ok for this, or would it have the wrong advance curve?
Posted 16 April 2005 - 04:52 PM
I have a 1330, with a 276, started off using the standard dizzy which was OK, but when the spindle broke I changed to an Aldon Yellow (No Vac), and it was far superior.
Posted 16 April 2005 - 04:55 PM
Selecting an advance curve is an art, not a science. Some may say that "this distributor or that" is better for a particular application. The truth is, each engine (installed in a vehicle) has different requirements and what is available "off the shelf" is always a compromise. The fact is, each dizzy really needs to be adjusted on a dyno for the car it's being installed in. Who has that kind of money apart from racers?
For some light reading on advance curves and distributors, visit Marcel Chichak's web site in Canada:
http://www.telusplanet.net/~chichm/
Go to the Tech Pages and read his article on Tuning Lucas Distributors
http://www.telusplan...lucastuning.pdf
Posted 16 April 2005 - 08:39 PM
Your best bet would be to call the guys at Aldon and tell them what you require.
