Identifing An A Series Engine
Posted 06 March 2008 - 08:23 PM
Anyone know how to identify an A series 1275 block.
It hasn't got an engine number plate on it, so i can't tell what it came out of.
It is an A+, in red. Other than that i don't know what else can tell what it is out of. Would any of the casting numbers be of any use?
It has got liners in it, if this means anything.
I've had it lying in my parents shed for the last 15 or so years and they have just got a new shed so they unearthed it while swapping stuff over into the new shed.
I think all the bits are there for it but it is in need of a rebuild or a new piston and liner.
So i thought i'd maybe get it built up, but i'd be interested to find out what it came out of originally.
Ian
Posted 06 March 2008 - 08:39 PM
look just below the cyl head on the back(exhaust mounting side) are there 2 rectangular sections?
you must have the head off too see the liners, measure the cylinder width or give us the numbers ontop of the pistons if you can read them.....
apart from that you cant really tell what the engine is until you strip it.....with the liners it could be a std 1275 thats been rebuilt in the past.
Posted 06 March 2008 - 08:54 PM
It is stripped at the moment, everything off it, i can see the liners poking out of the bottom of the cylinders.
I'll get the numbers off the pistons in the morning and if need be i'll get some photos.
I think (if i remember right) it will be an MG Metro engine, but as it will be 15yrs since i got it, my memory isn't what it used to be 15 years ago either.
Posted 06 March 2008 - 08:57 PM
Posted 06 March 2008 - 09:01 PM
A normal engine doesn't have liners in, do they?
Its a long time since i've done anything with mini's but i can never recall any engines i've done out with, having liners in them.
Posted 06 March 2008 - 09:08 PM
cant tell without a number.....if you get a picture of the cam then you may be able to tell more IF its 'original' to THAT engine!
Posted 06 March 2008 - 09:44 PM
Is an MG Metro block any different to any other block.
IS a 1275 block, quite simply a 1275 block, is there any difference in any of them other than the S and 1300GT engines?
Posted 06 March 2008 - 09:52 PM
no not with liners, it will have been rebuilt with liners fitted to keep
I think you'll find that some A series engines were built with liners fitted from new.
Posted 06 March 2008 - 09:54 PM
Any idea why some were built with and some with out. Was it for some reason then or not.no not with liners, it will have been rebuilt with liners fitted to keep
Ian
Posted 06 March 2008 - 09:56 PM
Apparently this it true, Bill Sollis mentions it in the 1380 build DVD.
Posted 06 March 2008 - 09:59 PM
Ian
It's probably a way of recovering a poorly cast or machined block. It could be that they broke through into the water jacket when block was first bored.
Edited by pogie, 06 March 2008 - 10:01 PM.
Another Mini fact
Posted 06 March 2008 - 10:03 PM
Posted 07 March 2008 - 07:53 AM
A series blocks the two holes for the alternator attachment are adjacent to the central core plug on the front, A+ they are nearer the third (rhs) one.
A series blocks are smooth, A+ have ribs..
or just take a picture and post up ( front and back )
Posted 09 March 2008 - 01:19 AM
I know its an A+ 1275cc, what i was after was how to tell what car it came out of originally, and to see if there was any differance between an MG Metro block and a standard 1275 block, it is standard bore but the big end shells have 010 stamped in them.
Ian
