Starter Motor Only Partially Engaging!?
Posted 07 March 2008 - 04:59 PM
Whats causing this? Could it be a dodgy starter or could it be that minispeed have sent me a high torque inertia type starter?
Posted 07 March 2008 - 05:13 PM
does the engine turn over at all, or does it just jam as soon as you try and start itIve got a flywheel with verto ring gear, and also a new, what i belive to be, high torque verto type starter. The problem is that the gear on the starter is only engaging on the flywheel by about 5/10 mm rather than the whole way.
Posted 07 March 2008 - 05:21 PM
Posted 07 March 2008 - 06:00 PM
it sounds as if you got the wrong starterIt will engage and try to start it for a fraction of a second and will then just spin, it doesnt seem as if its engaging far enough
Posted 07 March 2008 - 06:58 PM
Posted 07 March 2008 - 08:13 PM
its a possibility. but as you say you bought it from minispeed... well there is your answer!
Posted 07 March 2008 - 09:12 PM
Posted 08 March 2008 - 12:45 PM
Absolutly useless! Did they not bother testing these starters before selling them?!
Posted 08 March 2008 - 07:12 PM
Posted 08 March 2008 - 09:37 PM
Posted 09 March 2008 - 03:22 PM
Minispares are a good serivce however and i'm sure they'll sort you out.
did you get your discount?
Posted 09 March 2008 - 05:56 PM
