that sinking feeling....
miniman5
, Apr 18 2005 08:16 PM
20 replies to this topic
Posted 18 April 2005 - 08:16 PM
ado clever people, we went out to my freinds house on satday lunchtime and some some reason the wheels where whacking of the front arches, theve never done it before, i did have my geetar in there wich is heavy but im not sure what it is, think its the rubber thingis. what should i do? and what do i need to order?
Posted 18 April 2005 - 08:20 PM
You talking about the front wheels or back?!
Posted 18 April 2005 - 08:26 PM
hello sory for got to put the vitals in lol
its 1989 998, its th efront wheels that do it, i think the hocks could do with replacing to
i think its the ruybber cones not sure tho
Posted 18 April 2005 - 08:28 PM
why is some one pinching letters from your posts :erm:
Posted 18 April 2005 - 08:31 PM
what???
i need to change the engien mounting bush is this the thing i want? is it a good price?
bush thing
bush thing
Posted 18 April 2005 - 08:34 PM
whats a ENGIEN then
Posted 18 April 2005 - 08:36 PM
he's got dislexic fingers.... :tongue:
Posted 18 April 2005 - 08:37 PM
:tongue: it because he does'nt like smurfs
Posted 18 April 2005 - 09:06 PM
If its the front of the wheels touching the arches its sounds like a tie rod has bent, if the arches are riding on top of the wheels then it sounds like either the cones or the suspension might be up the creek.
Posted 18 April 2005 - 09:09 PM
Its normaly the ball worn through the plastic cupif the arches are riding on top of the wheels then it sounds like either the cones or the suspension might be up the creek.
Posted 18 April 2005 - 09:15 PM
Do you mean an actual engine mount or do you mean the stabilizer? The bushes you showed are for the stabilizer, the others are the rubber blocks at the bottom of the engine that bolt directly to the subframe.
Arthur
Arthur
Posted 19 April 2005 - 03:36 PM
its the stabiliser that needs doing
when you say the sus is 'up the creek' what do you mean? they guy who did the MOT said there fine, and why would the rod be bent?
Posted 19 April 2005 - 03:45 PM
I dunno why the rod would be bent (it might of hit something), but if the front of the wheels are rubbing on the arch, and they never used to, its usually a bent tie-rod that does it. And if the archs are rubbing on top of the wheel then theres several different causes. Which stabaliser are you talking about?!
Posted 19 April 2005 - 04:48 PM
the one that goes into the left hand side of teh block as you look at the engine with the bonnet open
