whats the length of std tie bars that are unbent....
i have HD adjustables that im wanting to put on my car.
say the length from the bottom arm long bolt too the large disc at the bush end...
Tie Bar Length...
ginigwunkle
, Mar 08 2008 10:21 PM
2 replies to this topic
Posted 08 March 2008 - 10:21 PM
Posted 08 March 2008 - 10:59 PM
14 5/16 Inches.
But..
The replacement tie rod may have a longer end spigot form the welded on flat washer to the step next to the threaded end. if too long the bushes will not fit.So try to compare to an old one if possible.
But..
Posted 08 March 2008 - 11:02 PM
i have two very bent ones so can have a look when i remove them, just wanted to know what they should be at.....
thank you!
thank you!
