Ok I am guessing this is a bad earth but where do I start.
1992 Rover Cooper 1.3i
Side lights come on fine, Headlights come on fine.
When I flash (pull back the light column) the headlights say on full and the spots come on as they should, but the headlights do not go upto main beam.
If I flick the column forward the spots come on as they should but the headlamps go to side lights.
Any ideas where I should begin?
Cooper Headlights
JamesM
, Apr 20 2005 02:33 PM
7 replies to this topic
Posted 20 April 2005 - 02:33 PM
Posted 20 April 2005 - 02:38 PM
do any of your cars have lights that work James?!
Posted 20 April 2005 - 02:39 PM
Yep the New Mini is ok but thats Dad's so it guess it doesn't count. I am not allowed out after dark anyway.
Posted 20 April 2005 - 02:57 PM
Since the lamps are on except when you "flash" I wouldn't be looking for a ground problem. The ground appears to be working or the low beam wouldn't function.
The problem is more likely in the high-beam wiring and/or the switch. The only way to sort these things out is to use a volt meter (and an assistant) along with a a wiring diagram. You have to check for voltage starting at the headlamps and work back through the wiring and switches until you get back to the fuse box (if it's necessary to go back that far). As you move backward from the lamps you'll eventually find where the voltage "disappears".
Posted 20 April 2005 - 03:07 PM
Check the butt connectors at the front under the bonnet slam panel, it's the first place they go.
Posted 20 April 2005 - 03:42 PM
Ok thanks, I will give it a shot over the weekend, after getting Pickups tail gates
Thanks for your help.
Posted 20 April 2005 - 09:13 PM
The butt connector on the blue/white (main beam) wire is the one you need. The problem is somewhere in the main beam supply wires from the flasher switch. The butt connector is the most likely place so start there and work your way back.
(Like DK said! )
(Like DK said! )
Posted 21 April 2005 - 02:05 PM
Blue and white, great thanks. Saves me going to the HBOL first
