How Much Is This Topic Worth?
#16
Posted 15 March 2008 - 09:32 PM
#17
Posted 15 March 2008 - 09:33 PM
#18
Posted 15 March 2008 - 09:43 PM
#19
Posted 15 March 2008 - 09:45 PM
#20
Posted 15 March 2008 - 09:47 PM
did it need any bod mods to fit the V12 ?
Which V12, series one or two?
#21
Posted 15 March 2008 - 09:50 PM
ive been looking for years
#22
(and LOL!! @ the other responses, especially seamus's!! )
Edited by yorkshirechris, 15 March 2008 - 09:52 PM.
#23
Posted 15 March 2008 - 09:52 PM
I've noticed this thread is only firing on 3 cylinders, what could be causing it?
I've checked all of the usual things
Tyre pressures
Coolant level
Emptied the ashtray
Had it resprayed pink
The damm thing still won't run correctly, any thoughts?
LOL!
#24
Posted 15 March 2008 - 09:53 PM
#25
the PMK235900975-p78-08mmwibblewibblecrapwibble-z, which although not a genuine part, was originally used on the mongolian export countryman 850 cooper S works automatic cabriolet clubman, with a wet subframe, but only when it was painted brown.
#26
Posted 15 March 2008 - 09:54 PM
Tyre pressures
Coolant level
Emptied the ashtray
Try wiggling each wheel side by side starting from the driver side and going anti-clockwise around the car.
Also check for wear on the passenger seat and swap the leads around randomly, hope that helps
#27
Posted 15 March 2008 - 09:55 PM
Tyre pressures
Coolant level
Emptied the ashtray
My car is lefthand drive, does this mean I should run round clockwise?
#28
Posted 15 March 2008 - 09:56 PM
Mine is the outer mongolian time lord special, does this make a difference?
#29
Posted 15 March 2008 - 09:57 PM
about what engine to put in my car ,it needs to be under 1000cc as im only 12,but it needs to be able to do about 170mph-ish,
oh also has any body ever put a full london bus interior in a mini?
Pics?
#30
Posted 15 March 2008 - 09:58 PM
