I've got a 1.5 ratio roler tip rockers to go on my mini but dont know the valve clearences for this raito
can any one help
valve clearences
Bungle
, Apr 21 2005 08:55 PM
6 replies to this topic
Posted 21 April 2005 - 08:55 PM
Posted 25 April 2005 - 09:26 PM
As a basic rule of thumb you add a couple of thou to whatever your clearances are already when adding 1.5 rockers.
Phil.
Phil.
Posted 25 April 2005 - 09:29 PM
that sounds a bit hit and miss
i thought i read somewhere that you divide the standard amount by 1.25 and then times by 1.5 is this right ?
Posted 25 April 2005 - 10:04 PM
i was told by M.E.D that the gaps are the same as standard rockers, i've been running my engine like this for about 6 years now with no probs.
Posted 25 April 2005 - 10:17 PM
I heard that you can run smaller gaps with roller rockers (or was that cardon fiber push rods ), but i dont know !
i run standard gaps :grin:
no problems(yet)been on for 6 months now
Edited by Woody, 25 April 2005 - 10:18 PM.
Posted 26 April 2005 - 09:43 AM
Yes the gap should be the same as I understand it, the amount the push rod increases in length due to heating is negligable really so the extra length of the rocker won't have all that much of an effect. It's the amount the valves increase (particularly the exhaust valves) which is important, and the new rockers won't change that.
Posted 26 April 2005 - 06:08 PM
I run standard rockers at .010 thou and roller tips were at .012 thou
